Старый 05.12.2014, 19:11   #1
lcs: December release notes
Источник: http://blogs.msdn.com/b/lcs/archive/...ase-notes.aspx
The Microsoft Dynamics Lifecycle Services team is happy to announce the immediate availability of the December release of Lifecycle Services.
PREVIEW RELEASE
This release includes a reworked experience with several preview features. These include:
  • SharePoint Online integration has relaxed validation rules for URLs
  • Dozens of bug fixes
NEW FEATURES
  • All services have been updated for CU8
    • Upgrade analysis can be used for moving from AX 2012 to AX 2012 R3 CU8
    • Issue search can be used to find known issues for AX 2012 R3 CU8. Search for "CU8 known issue". (The quotation marks are required)
  • Cloud-Hosted Environments includes the following updates:
    • The Test environment (previously referred to as the Standard Dev/Test environment) has been updated for AX 2012 R3 CU8. The CU8 version is deployed by default. If you want to deploy the AX 2012 R3 version, click Advanced settings > Supported version during deployment.
    • CU8 demo data is included on the SQL Server VM disk for easy import.
    • RemoteApp is supported in Test environments when a Remote Desktop Services instance is deployed. You can select the RemoteApp option during deployment when you click Advanced settings > Customize remote desktop services. For more information about RemoteApp, see http://azure.microsoft.com/en-us/services/remoteapp/.
    • Azure Basic tier VMs are no longer supported, because they are not compatible with our deployment methods and application needs. Only Standard tier or higher VMs are available for deployment.
      Note: CU8 Demo and Retail environments are not yet available, but will be coming soon.
  • System Diagnostics contains 8 new rules for General Ledger and Budgeting that help identify data inconsistencies that often cause issues for Management Reporter integrations:
    • MainAccounts that don’t have a corresponding account category assigned
    • An invalid Ledger value assigned within a General Journal Entry, Budget Register Entry, or Budget Planning Entry
    • A child record with no corresponding header record within a General Journal Account Entry, Budget Register Entry, or Budget Planning Entry
    • Any invalid DataAreaID assigned within a Budget Register Entry
lcs: November release notes Blog bot DAX Blogs 0 31.10.2014 10:11
lcs: September release notes Blog bot DAX Blogs 0 10.09.2014 05:38
lcs: May release notes Blog bot DAX Blogs 0 02.05.2014 02:34
lcs: February release notes Blog bot DAX Blogs 0 28.02.2014 04:47
Часовой пояс GMT +3, время: 03:39.
