Старый 28.01.2015, 01:13   #1
bojensen: Use a Dynamics AX display method in SSRS report | Arjen Stolk
Источник: http://blogs.bojensen.eu/2015/01/27/...arjen-stolk-2/
There are a lot of display methods that I would like to use in a SSRS report. Here is an example of the use of the display method ‘reservedPhysicalInSalesUnit()’ from the sales line. In order to use this method, you need to be able to identify the sales line. For this you need the SalesId…
Read more →
kamalblogs: SSRS Tip: Using invisible parameters in contracts – Dynamics AX 2012 Blog bot DAX Blogs 2 30.09.2013 17:50
bojensen: Dynamics AX 2012 error when running SSRS-reports just after deleting a table field from report’s temporary table – Addicted2AX / Addicted2SQL Blog bot DAX Blogs 0 09.01.2013 17:11
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Часовой пояс GMT +3, время: 23:50.
