Старый 23.09.2015, 01:01   #1
demoded is offline
demoded
39 / 101 (4) +++++
Thumbs up DIXF. Data Import Export Framework пошаговые руководства в картинках
Чувак напилил уже кучу статей с картинками по импорту разных данных через DIXF.
http://shafeaa.blogspot.co.nz/p/di.html
Import Data From an ODBC Through DIXF
Convert Field Values During The Importing Process Through DIXF
Assign Default Values Automatically During the importing process through DIXF
Configure DIXF To Automatically Generate Unique Key Using Number Sequence
Importing purchase orders using DIXF
Import Released products using DIXF
Import Projects using Data Import framework AX 2012 R3
Import Workers using Data Import framework AX 2012 R3
Import Assets using Data Import framework | AX 2012 R3
Import Vendor Groups using Data Import framework | AX 2012 R3
Import Main Accounts using Data Import framework | AX 2012 R3
Import Vendors using Data Import framework | AX 2012 R3
Import Customers using Data Import framework | AX 2012 R3
Import Financial Dimension using Data Import framework | AX 2012 R3
За это сообщение автора поблагодарили: AlGol (1), trud (2), sukhanchik (4), Logger (3), Ace of Database (3), Raven Melancholic (2), Ivanhoe (5), gl00mie (3), Stitch_MS (3), G.Menshikh (1), Kabardian (2), pedrozzz (2).
dixf, import, integration, r3, ax2012
Dynamics AX Sustained Engineering: Announcing an update to enable the use of SQL Server 2014 with the AX 2012 R2 CU7 version of the Data Import/Export Framework (DIXF) Blog bot DAX Blogs 0 23.03.2015 22:12
emeadaxsupport: Importing a General Journal using Data Import/Export Framework AX 2012 Blog bot DAX Blogs 0 17.07.2014 20:12
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework (Old name - Data Migration Framework) is now available on Information source Blog bot DAX Blogs 0 16.03.2013 15:12
Часовой пояс GMT +3, время: 03:47.
