Старый 20.10.2015, 13:11   #1
sashanazarov: Table extension framework
Источник: http://sashanazarov.blogspot.com/201...framework.html
There is a great article on how to use the table extension framework in AX 2012.
Keep in mind that if the parent table's primary key is not RecId-based, but the table has CreateRecIdIndex property set to Yes, then the relation on step #1 should be created based on "Single field AlternateKey based"; otherwise the new feld will potentially have wrong type, and it will not be possible to use it in the SysExtensionSerializerExtensionMap map.
And remember to add a DeleteAction to the parent table.
ax_gfm_framework_team: The Microsoft Dynamics AX 2012 extension framework – Part 3 Blog bot DAX Blogs 0 14.11.2012 01:12
ax_gfm_framework_team: The Microsoft Dynamics AX 2012 extension framework – Part 2 Blog bot DAX Blogs 0 14.11.2012 01:12
ax_gfm_framework_team: The Microsoft Dynamics AX 2012 extension framework – Part 1 Blog bot DAX Blogs 0 14.11.2012 01:12
Inside Dynamics AX 4.0: RunBase Framework Extension Part IV Blog bot DAX Blogs 0 02.10.2007 04:49
Inside Dynamics AX 4.0: RunBase Framework Extension Part III Blog bot DAX Blogs 0 02.10.2007 04:49
Часовой пояс GMT +3, время: 12:00.
