Старый 20.12.2015, 09:16   #1
mfp: X++ in AX7: Forms implementing interface
Источник: http://blogs.msdn.com/b/mfp/archive/...interface.aspx
Forms can now implement interfaces.
public class MyForm extends FormRun implements SysPackable
This is pretty cool, because:
  1. The compiler will validate that the interface is correctly implemented.
  2. No longer a need to use reflection, like hasFormMethod(), to determine if it is safe to call the method.
  3. No longer a need to downcast to object to invoke the methods. Now cast to the interface:
    var sysPackable = myFormRun as SysPackable;
    if (sysPackable)
    sysPackable.pack();
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 TECHNICAL PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
mfp: X++ in AX7: Const keyword Blog bot DAX Blogs 0 17.12.2015 12:02
mfp: X++ in AX7: Readonly keyword Blog bot DAX Blogs 3 15.12.2015 18:22
mfp: X++ in AX7: Reals are decimals Blog bot DAX Blogs 0 14.12.2015 22:11
mfp: X++ in AX7: Static event subscription Blog bot DAX Blogs 0 11.12.2015 11:11
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 16:26.
