Старый 19.02.2016, 08:12   #1
emeadaxsupport: Transportation scenario – Manual rating
Источник: https://blogs.msdn.microsoft.com/axs...nual-rating-2/
Scenario In some circumstances, rules for the calculation of transportation charges cannot be defined in advance. In this situation, companies may need to manually define the rate based on the information received from transporters/carriers. The manually defined rate should then be recorded in the system, so that freight bills and related invoices can be matched... Read more
emeadaxsupport: How to print BOL from Transportation Management without using Warehouse Management Blog bot DAX Blogs 0 12.03.2015 18:11
emeadaxsupport: How to use the Manual Billing Rule for Projects in Microsoft Dynamics AX 2012 R2 and AX2012 R3 Blog bot DAX Blogs 0 03.03.2015 19:11
DynamicsAxSCM: Third-party Transportation Management (TMS) engines (UPS, FedEx, Progistics, PCMiler) Blog bot DAX Blogs 0 10.10.2014 12:11
emeadaxsupport: 4. Solving Fill Utility errors on Microsoft Dynamics AX 2012 - Error executing code: Wrong argument types for comparison (another scenario) Blog bot DAX Blogs 2 08.02.2012 09:21
Часовой пояс GMT +3, время: 07:50.
