Старый 25.03.2016, 05:29   #1
organicax: Using item tracing to view where a product was purchased and sold
Источник: http://organicax.com/2016/03/24/usin...ased-and-sold/
If you work with items and specifically batch items then you are using batch to identify the product. This can then be used to trace where the product came from and where it was sent to if there is an issue with that batch.
The item tracing gives you are consolidated view to search and track the product. You can list suppliers and which customers the product was sold to. As well get a report listing to be able to use as a call list to call customers. This can be handy in situations where you want to notify your trading partners of an issue with product.
Here is a quick overview.
AX2012 R3 CU9.
Cheers
Lachlan
Filed under: Procurement and sourcing, Product information management, Sales and marketing
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
dynamicsaxtraining: Quarantine management Blog bot DAX Blogs 0 11.01.2011 21:11
dynamicsaxtraining: Item setup: Item group Blog bot DAX Blogs 0 12.11.2009 17:05
Часовой пояс GMT +3, время: 08:56.
