Старый 15.08.2005, 09:29   #1
johndoe is offline
johndoe
Дамы и господа!
Pls подскажите, где найти информацию по следующим темам к экзамену (цитирую по Partner Source, думаю, понятно без перевода ):
- standard Navision naming conventions for variable and function names;
- standard Navision naming conventions for labels (в оригинале - for forms and labels, но первое вполне ясно);
- standard Navision report headers (это COMPANYNAME вверху слева и дата, номер страницы и USERID вверху справа, или я ошибаюсь?) and standard look of reports.
Заранее спасибо!
Старый 15.08.2005, 10:23   #2
Шрэк is offline
Шрэк
Аватар для Шрэк
645 / 24 (2) +++
Сообщение от johndoe
Дамы и господа!
Заранее спасибо!
А как экзамен называется?
По поводу
Может как ниже? Если да, то это документ NA GUI Guide.
Report Header
Report Title Guidelines
Always use the report name in the title of a report.
The title must begin with a capital letter, and it must never end with a period.
Guidelines for Reflecting Option Choices
Nondefault option choices from the Options tab in the Print dialog box should, as a general rule, be reflected in the report header. However, option choices that do not have any influence on the data shown in the report, for example, whether to print objects on separate pieces of paper or not, are not affected by this rule.
Examples: An option choice such as "Include all customers that have a balance" are reflected in the report header as "This report also includes customers that only have balances." The option choice "Show amounts in LCY" is reflected as "All amounts are in LCY." A choice of a period is reflected as "Period: 01-01-99..31-12-99", for example.
Guidelines for Reflecting Table Filters
Table filters should be reflected in the report header. Table filters have the form "Table: Table filter" for example "Customer: Blocked=No, Credit Limit>10000".
This rule does not apply to filters that do not concern the first page in a report. For example, on an invoice, do not display if the user has use a filter when they decided which invoices to print. Each invoice starts on the first page and when you see a particular invoice, you do not want to see which other invoices have been printed at the same time.
MBS Certified Master in Navision Developer
Старый 15.08.2005, 10:32   #3
johndoe is offline
johndoe
Сообщение от Роман
Navision C/SIDE Solution Development.
За цитату из GUI Guide большое спасибо Руки до него все не доходят, да и в списке литературы его нет (правда, там и так почти ничего нет ).
Старый 15.08.2005, 10:50   #4
Шрэк is offline
Шрэк
Аватар для Шрэк
645 / 24 (2) +++
Сообщение от Роман
Да, не за что.
Так и думал, что девелопмент. А версия какая? 3.01 или новый из серии NA по версии 4.0?
Старый 15.08.2005, 11:29   #5
johndoe is offline
johndoe
Сообщение от Роман
Материалы по подготовке к 3.60.
Старый 16.08.2005, 10:49   #6
Jackal1 is offline
Jackal1
Эта инфа есть в PDFнике Navision Attain Solution Development,
правда для 3.01, но я не думаю что там что то поменялось
Старый 17.08.2005, 09:53   #7
johndoe is offline
johndoe
Сообщение от Jackal
2Jackal:
Видимо, поменялось, т.к. неоднократное прочтение Solution Development для Navision 3.10 не дало ответа на животрепещущий вопрос Тем не менее, спасибо!
2All:
Может, кто еще чего скажет?
Старый 17.08.2005, 10:23   #8
Шрэк is offline
Шрэк
Аватар для Шрэк
645 / 24 (2) +++
Сообщение от Jackal
Согласен. Вообще не понятно как johndoe сдает экзамен по девелопменту версии 3.60? Такого на сайте VUE нет (ни русского, ни международного экзамена). Есть международный по версии 4.0 и русский по версии 3.01. Знакомый сдал весной по версии 3.01 и сказал, что информации в PDFнике Navision Attain Solution Development достаточно для сдачи экзамена.
Может я чего-то не понимаю? Откуда взялся экзамен по 3.60?
Старый 18.08.2005, 09:28   #9
johndoe is offline
johndoe
Post
Сообщение от Роман
Сообщение от Jackal
Спокойствие, Роман, только спокойствие
Ммм.... В самом деле, почему по 3.60? Видимо, впопыхах очепятался Привык везде версию рисовать
А что касается содержания, то материалов только одной книги Solution Development для сдачи экзамена недостаточно, на что указывает, в том числе, и Preparation Guide в закрытой области сайта MBS.
Старый 19.08.2005, 18:16   #10
Jackal1 is offline
Jackal1
В прошлую пятницу сдавал экзамен по девелопменту версии 3.01, на русском.
Вопросов по маркировке обьектов не припоминаю, хотя на тренинге для сдачи этого экзамена подобная тема рассматривалась.
Старый 22.08.2005, 10:17   #11
Шрэк is offline
Шрэк
Аватар для Шрэк
645 / 24 (2) +++
Сообщение от Jackal
Каков результат, если не секрет?
Старый 22.08.2005, 12:48   #12
Jackal1 is offline
Jackal1
Сообщение от Роман
Сообщение от Jackal
Сдал
Старый 22.08.2005, 13:51   #13
Шрэк is offline
Шрэк
Аватар для Шрэк
645 / 24 (2) +++
Ours congratulations
Старый 22.08.2005, 14:27   #14
Jackal1 is offline
Jackal1
Спасибо, спасибо
Часовой пояс GMT +3, время: 20:42.
