Старый 22.07.2016, 16:11   #1
organicax: Creating a batch attribute group.
Источник: https://organicax.com/2016/07/22/cre...tribute-group/
In a previous post we had a look at creating a batch attribute. If you have multiple attributes you want to associated with items then it might be helpful to add them to a group. Once added to the group then you can add them to an item in one step instead of adding individually.
Here is a quick overview.
AX2012 R3 CU10
Cheers
Lachlan
Filed under: Microsoft Dynamics AX
organicax: Creating a batch attribute and assigning to an item Blog bot DAX Blogs 0 22.07.2016 10:11
organicax: Registering vendor batch information – non-wms Blog bot DAX Blogs 0 24.03.2016 09:11
axinthefield: Optimizing AX Batch Performance - Batch Group Configuration Blog bot DAX Blogs 0 01.04.2011 13:11
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Часовой пояс GMT +3, время: 22:21.
