Старый 01.10.2016, 04:15   #1
organicax: New released item in AX7
Источник: https://organicax.com/2016/09/30/new...d-item-in-ax7/
The process of creating a released item is basically the same in AX7 if you are familiar with AX2012. With the new UI we have some new options of how we access that functionality, for example the category and product management workspace. From here you have an option to create the released item in the company you are working in.
Here is a quick overview.
AX7 Build 7.0.4230.16130
As well you can have a look at the released product maintenance workspace.
Cheers
Lachlan
Filed under: Product information management
organicax: Change BOM Item Blog bot DAX Blogs 0 01.09.2016 08:13
organicax: WMS work grouping at released to warehouse based on item Blog bot DAX Blogs 0 06.08.2016 03:27
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 18:07.
