Старый 01.10.2016, 04:15   #1
organicax: Vendor invoice with working, matching test and posting to GL
Источник: https://organicax.com/2016/09/30/ven...posting-to-gl/
In a previous post we had a look at a vendor invoice with approval workflow and invoice matching. Now while that invoice is sitting in the system for approval it isn’t posted to the general ledger. So if this spans a month end period for example when you report your P&L your expenses might be understated. You can add some additional steps to get a posting if you use the invoice register.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Accounts payable
Navigate Into Success: Fixing Preview Posting: Part 2 Blog bot Dynamics CRM: Blogs 0 16.10.2015 08:00
NAV Team: Application Test Toolset for Microsoft Dynamics NAV 2013 Blog bot Dynamics CRM: Blogs 0 07.11.2012 17:27
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
NAV Team: Test Automation and Test Data Blog bot Dynamics CRM: Blogs 0 01.10.2010 12:56
Часовой пояс GMT +3, время: 03:28.
