Старый 04.10.2016, 12:11   #1
organicax: Inventory by item group aging report
Источник: https://organicax.com/2016/10/03/inv...-aging-report/
If you are looking for a report that can give you a simple view of on-hand and some options for how you show on-hand over a period of time then the inventory by item group aging report might be something that can help. It will allow you to set date buckets so you can see the on-hand balances relevant to those buckets. You can run it by item or item group. So this could be helpful when looking at setting minimums for example you can see some history.
As well you can look at it as value or quantity.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
You experience issues when you run the "Physical inventory by inventory dimension" report and the "Physical inventory by item group" report in Microsoft Dynamics AX 2009 Vadik DAX: База знаний и проекты 0 27.08.2010 23:00
Часовой пояс GMT +3, время: 23:38.
