Старый 09.10.2016, 19:12   #1
organicax: Vendor hold release date
Источник: https://organicax.com/2016/10/09/ven...-release-date/
If you are looking at putting vendors on hold there are a few different type of holds. When you set these you can specify the vendor hold release date. You can then use it to review those holds and check which ones you might be able to take off hold.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Accounts payable
organicax: Session date selection in AX7 Blog bot DAX Blogs 0 05.10.2016 09:11
organicax: Receipt date is not valid on customer calendar Blog bot DAX Blogs 0 07.04.2016 20:13
organicax: Quantity available to release is zero on the release to warehouse form Blog bot DAX Blogs 0 12.03.2016 21:12
DynamicsAxSCM: Troubleshooting the product release process Blog bot DAX Blogs 0 05.10.2012 17:11
Часовой пояс GMT +3, время: 20:28.
