Старый 12.10.2016, 00:14   #1
organicax: Using a record template to setup a resource
Источник: https://organicax.com/2016/10/11/usi...up-a-resource/
If you have a number of resources that you need to setup that are somewhat similar, you can use record templates to copy of a previous resource you had setup. This will save you some typing, all you will need to do is change some of the details.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
atinkerersnotebook: Creating Record Templates to simplify new data setup Blog bot DAX Blogs 0 01.09.2016 23:11
atinkerersnotebook: Creating Record Templates to simplify new data setup Blog bot DAX Blogs 0 01.09.2016 15:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
organicax: WMS Wave template setup – process at release to warehouse Blog bot DAX Blogs 0 12.03.2016 04:36
Часовой пояс GMT +3, время: 22:58.
