Старый 05.11.2016, 20:11   #1
organicax: Setting up PowerBI to access your D365 instance.
Источник: https://organicax.com/2016/11/05/set...d365-instance/
PowerBI is the primary business intelligence tool for D365 so when you setup your instance of D365 you will have to go an configure the connection between the two. You can see a written set of notes on the help wiki here
Configuring Power BI integration for workspaces</p>
Here is a quick overview.
D365FO 1611 – Update3 (7.0.4307.16141)
It’s referenced in the wiki notes but you the website used in the video to setup the client id is
http://dev.powerbi.com/apps
Cheers
Lachlan
Filed under: Business intelligence
organicax: Setting up LCS and a machine for data template and config manager. Blog bot DAX Blogs 0 31.10.2016 22:11
organicax: Setting up a new expense category and GL account Blog bot DAX Blogs 0 12.10.2016 06:25
organicax: Setting up customer contacts Blog bot DAX Blogs 0 05.04.2016 11:11
organicax: Setting up a demo user to access your new Dynamics AX instance Blog bot DAX Blogs 0 17.03.2016 01:15
ошибка в AIF syl DAX: Программирование 14 20.08.2015 15:25
Часовой пояс GMT +3, время: 17:02.
