Старый 03.02.2017, 09:11   #1
dynamicsaxhints: How to copy cross-reference from one environment to another
Источник: http://dynamicsaxhints.blogspot.com/...-from-one.html
Cross-reference is a very useful tool in Dynamics AX, but cross-reference update requires a lot of time and resources. I want to share a simple way to copy cross-reference data.
Problem description
Copy cross-reference from one development environment to another, provided environments are identical.
Hints
Use bcp utility for export and import.
Solution
Cross-reference tables contain a lot of data, for example standard application with minor modifications in AX 2012 CU8:
XREFNAMES: 1.25 million records, 500MB space
XREFPATHS: 2.46 million records, 1400MB space
XREFREFERENCES: 14.35 million records, 6500MB space
Export
The following bat file can be used to export XREF* tables:
bcp MicrosoftDynamicsAX.dbo.XREFNAMES out XREFNAMES.txt -c -T
bcp MicrosoftDynamicsAX.dbo.XREFPATHS out XREFPATHS.txt -c -T
bcp MicrosoftDynamicsAX.dbo.XREFREFERENCES out XREFREFERENCES.txt -c -T
bcp MicrosoftDynamicsAX.dbo.XREFTABLERELATION out XREFTABLERELATION.txt -c -T
Where:
- MicrosoftDynamicsAX is Dynamics AX database name
- argument -c performs the operation using a character data type
- argument -T specifies that the bcp utility connects to SQL Server with a trusted connection using integrated security.
Export took 2 minutes, 4 *.txt files were created in the same folder:
Import
All records in XREF* tables must be deleted in destination database before import:
TRUNCATE TABLE XREFNAMES
TRUNCATE TABLE XREFPATHS
TRUNCATE TABLE XREFREFERENCES
TRUNCATE TABLE XREFTABLERELATION
The following bat file can be used to import XREF* tables:
bcp MicrosoftDynamicsAX.dbo.XREFNAMES in XREFNAMES.txt -c -T
bcp MicrosoftDynamicsAX.dbo.XREFPATHS in XREFPATHS.txt -c -T
bcp MicrosoftDynamicsAX.dbo.XREFREFERENCES in XREFREFERENCES.txt -c -T
bcp MicrosoftDynamicsAX.dbo.XREFTABLERELATION in XREFTABLERELATION.txt -c -T
Import took about 10 minutes.
Conclusion
Cross-reference can be copied in approximately 15 minutes from one development environment to another.
emeadaxsupport: How to delete On-premise environment from LCS project Blog bot DAX Blogs 0 27.06.2016 22:12
How to update cross-reference in batch Blog bot DAX Blogs 0 29.05.2014 20:12
Microsoft Dynamics CRM Team Blog: How to Reference Assemblies from Plug-ins Blog bot Dynamics CRM: Blogs 0 10.11.2010 01:11
Часовой пояс GMT +3, время: 10:18.
