Старый 04.02.2017, 03:29   #1
organicax: RFQ Case number vs request for quotation number
Источник: https://organicax.com/2017/02/03/rfq...tation-number/
In a previous post we had a look the RFP Journal. It’s worth understand the difference between the case number and the RFQ number as you will see it as an administrator and what the vendor would see on the portal.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: RFQ default payment terms Blog bot DAX Blogs 0 04.02.2017 03:29
organicax: Number sequence wizard Blog bot DAX Blogs 0 02.11.2016 01:11
organicax: User preference for date, time and number format in the new Dynamics AX Blog bot DAX Blogs 0 15.03.2016 23:11
organicax: Basic request for quotation process Blog bot DAX Blogs 0 15.03.2016 04:48
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
Часовой пояс GMT +3, время: 17:25.
