Старый 14.08.2017, 05:37   #1
stephenmann: AX 2012 AOS not starting after CU12 update
Источник: https://www.stephenmann.net/single-p...er-CU12-update
Some people may be experiencing their AOS not starting after applying the CU12 kernel update.
Exception code: 0xe0434352
Faulting application path: C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAx\Bin\Ax32Serv.exe Faulting module path: C:\Windows\system32\KERNELBASE.dll
The exception code refers to a .NET runtime exception.  You should find that installing .NET framework 4.6 will resolve this issue.  The installer does not check this as a prerequisite.
.net Framework 4.6 web installer is available here:
https://www.microsoft.com/en-au/down....aspx?id=48130
dynamicsaxse: May-June 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 21.06.2017 00:12
dynamicsaxse: April release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 07.04.2017 20:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
amer-ax: It was a great day! Blog bot DAX Blogs 3 29.12.2012 01:02
Часовой пояс GMT +3, время: 13:30.
