Старый 14.09.2017, 13:11   #1
25,643 / 848 (80) +++++++
yetanotherdynamicsaxblog: Error when installing Reporting Extensions for AX2012 R3 on SQL 2014 SSRS
Источник: http://yetanotherdynamicsaxblog.blog...reporting.html
Hi
I could not really find any posts on this out there, so I decided to just share this here.
You may experience installation errors when you try to install Reporting Extensions for AX2012 R3 on SQL 2014. The setup crashes internally, rolls back the installation and fails.
In the installation log you will see the error "Version string portion was too short or too long".
The solution is available on LCS as a downloadable hotfix KB3216898 (released 10th of January 2017) here:
https://fix.lcs.dynamics.com/Issue/Resolved?kb=3216898&bugId=3800976
Unpack the content of the hotfix and slipstream it as part of your AX2012 R3 installation and run the installation again. Now it will work.
Just to make this sure people find this post if they search for the errors, I'll add the full call stack below:
An error occurred during setup of Reporting Services extensions.
Reason: Version string portion was too short or too long.
System.ArgumentException: Version string portion was too short or too long.
at System.Version..ctor(String version)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.SrsWmi.get_ReportManagerUrl()
at Microsoft.Dynamics.Setup.ReportsServerInstaller.GetOrCreateServerConfiguration(String instanceName, String sharePointServiceApplicationSite, Boolean& createdConfiguration)
at Microsoft.Dynamics.Setup.Components.ReportingServicesExtensions.InstallConfigurationFiles(String instanceName, String sharePointServiceApplicationSite, Boolean& createdConfiguration)
at Microsoft.Dynamics.Setup.Components.ReportingServicesExtensions.RunReportingSetupManagerDeploy()
bojensen: SQL Server Data Tools for SQL Server 2014 is available – SQL Server Data Tools Team Blog Blog bot DAX Blogs 0 14.01.2015 20:11
emeadaxsupport: Installing the AX 2012 R3 Async Server to a Clustered SQL Server Environment Blog bot DAX Blogs 0 05.12.2014 19:11
Rahul Sharma: Dynamics AX 2012 & SQL Reporting Services 2012 Reporting Extensions Error Blog bot DAX Blogs 0 23.10.2012 04:23
NAV reporting: Building a Matrix Report in Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 28.08.2009 18:26
Nav developer: Basic SQL - Overview of NAV specific SQL features for application consultants Blog bot Dynamics CRM: Blogs 0 05.11.2008 11:52
Часовой пояс GMT +3, время: 20:12.
