Старый 26.03.2018, 20:13   #1
mohsinkhalid: Solution: Data Entity synchronization errors in #Dyn365FO
Источник: https://mohsinkhalid.com/2018/03/26/...s-in-dyn365fo/
{feed:content:encoded
mohsinkhalid: #D365 Solution: The property ‘ComputedFieldMethod’ must be set with the name of a valid data entity method if ‘IsComputedField’ is set to ‘Yes’. Blog bot DAX Blogs 0 21.03.2018 21:11
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
stoneridgesoftware: Automated Data Entity Import Using DIXF in Dynamics AX Blog bot DAX Blogs 0 07.08.2017 20:19
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 00:15.
