Старый 30.07.2018, 20:13   #1
d365technext: Deploy package using LCS
Источник: http://d365technext.blogspot.com/201...using-lcs.html
Using following steps you can create deploy-able package and deploy through LCS.
Step-1 Open Visual studio and click on Dynamics365 Menu and select create deployment package from the deploy menu item.
Step-2 Select your model and set the output path of the model and click OK.
Step-3 Login to LCS then navigate to your project.
Ste-4 click on hamburger icon and select Asset library.
Step-5 Now select software deploy-able package and click on + Icon to add your custom package.
Step-6 Enter the package name and description. would be great if you arefollow the any naming sequence for packages.
Step-7 click on Add file button to upload your deploy-able package.
Step-8 Now click on browse and select package then click on uplaod.
Step-9 You can find the package in the tab of software deploy-able tab Once package uploaded successfully.
Step-10 Once LCS mark package as valid. then goto your environment.
Step-11 Now click on Maintain and select apply update.
Step-12 Select your package and click on apply.
Package deployment will start in few seconds . LCS will show you progress of every steps.
Once package completed sign Off the package, So it will visible to you on production deployment as well.
Please feel free to contact me if you are facing any issue during implementation of this blog.
d365technext: Upgrade Environment using LCS D365 Blog bot DAX Blogs 0 30.07.2018 20:13
lcs: Issues with environment and package deployments that are triggered through LCS Blog bot DAX Blogs 0 16.12.2017 06:26
palleagermark: Package problem with LCS Code Upgrade to July 2017 release Blog bot DAX Blogs 0 18.08.2017 00:12
lcs: Known Issue: Applying package fails on environments deployed with App 7.0 or App RTW version Blog bot DAX Blogs 0 17.08.2017 11:11
lcs: Known Issue: Package deployment progress not visible in the UI in LCS Blog bot DAX Blogs 0 17.08.2017 05:02
Часовой пояс GMT +3, время: 08:44.
