Старый 12.10.2018, 15:11   #1
goshoom: Printing reports from code in D365FO
Источник: http://dev.goshoom.net/en/2018/10/pr...ode-in-d365fo/
A comment below my blog post Printing reports from code in AX2012 asked me to provide an example for D365FO. Here is it.
The code is virtually identical. Only writing a file to a shared folder doesn’t make a good sense in cloud, therefore I changed the code to return the file to user for download.
SrsReportRunController controller = new SrsReportRunController();SysUserLicenseCountRDPContract rdpContract = new SysUserLicenseCountRDPContract();SRSPrintDestinationSettings settings; // Define report and report design to usecontroller.parmReportName(ssrsReportStr(SysUserLicenseCountReport, Report));// Use execution mode appropriate to your situationcontroller.parmExecutionMode(SysOperationExecutionMode::Synchronous);// Suppress report dialogcontroller.parmShowDialog(false); // Explicitly provide all required parametersrdpContract.parmReportStateDate(systemDateGet());controller.parmReportContract().parmRdpContract(rdpContract); // Change print settings as neededsettings = controller.parmReportContract().parmPrintSettings();settings.printMediumType(SRSPrintMediumType::File);settings.fileFormat(SRSReportFileFormat::Excel);settings.fileName('UserLicenseCount.xlsx'); // Execute the reportcontroller.startOperation();
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
goshoom: Printing reports from code in AX2012 Blog bot DAX Blogs 0 24.11.2013 21:11
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 17:00.
