Старый 02.12.2018, 21:17   #1
mark_brummel: Compiling a 2000+ Objects Extension
Источник: https://dynamicsuser.net/nav/b/mark_...ects-extension
Let’s start diving into working with Extensions in Real Life. I have a lot to blog about and at first I thought I would blog about a very small extension but I’m sure you’ve all seen that. Let’s start big! At NAVTechDays I showed you the extension I created with the ForNAV converter that resulted in 2149 files which compiles and executes. I made the extension work on Business Central OnPrem, installed on my local box with the RTM version. What is the Build Time? It must be horrible… You...(read more)
mark_brummel: Three ways to use extension data in C/Side Blog bot NAV: Blogs 0 31.07.2018 02:51
mark_brummel: Converting an ISV solution to an extension: Update 1 Blog bot NAV: Blogs 0 05.07.2018 23:11
mark_brummel: Converting an ISV solution to an extension: The Beginning Blog bot NAV: Blogs 0 02.07.2018 21:13
mark_brummel: Record Zoom Extension Blog bot NAV: Blogs 0 24.06.2018 17:12
mark_brummel: Tip #58 | Run Extension Objects Blog bot NAV: Blogs 0 20.05.2017 15:16
Часовой пояс GMT +3, время: 07:13.
