Старый 24.06.2020, 15:11   #1
crmtipoftheday: Tip #1369: New user cannot see environment
Источник: https://crmtipoftheday.com/1369/new-...ee-environment
I recently saw the following scenario in several environments:
  • New user added and license for Dynamics 365 or Power Apps assigned
  • User granted security role in an environment
  • User can only see default environment when going to make.powerapps.com or power platform admin center, but they see all environments at Power Automate.
The reason for this that I heard from multiple people is “it’s some kind of caching.” It isn’t browser caching, because trying different computers and browsers, the experience is the same. So it may be some caching in the maker portal.
The solution we discovered was that if you have someone with access to the environment share a canvas app in the environment with the user and have the user run the app one time.
After that the user will now see the environment, both in maker portal and the admin portal.
The Camouflage of an Eastern Bearded Dragon (Pogona barbata) blends almost perfectly with its environment in our cover photo courtesy Andrew Mercer / CC BY-SA
crmtipoftheday: Tip #1351: Flows not triggering after environment copy Blog bot Dynamics CRM: Blogs 0 06.05.2020 16:11
crmtipoftheday: Tip #1309: 213 revisited: Embedded user role list Blog bot Dynamics CRM: Blogs 0 07.10.2019 16:47
crmtipoftheday: Tip #1297: Base your base role on the CDS User role Blog bot Dynamics CRM: Blogs 0 28.08.2019 21:18
crmtipoftheday: Tip #1080: Setting KPIs for user adoption Blog bot Dynamics CRM: Blogs 0 21.02.2018 04:31
Часовой пояс GMT +3, время: 16:36.
