Старый 30.08.2021, 20:12   #1
Alexdmeyer: Creating a Zip File From Multiple MemoryStreams in D365FO
Источник: https://alexdmeyer.com/2021/08/30/cr...ams-in-d365fo/
I recently had a requirement to take many pieces of data from D365FO, create a CSV file out of each data piece, and then wrap these files in a zip file for easy downloading by an end user. In my case, the requirement was that all of the data should be held in memory (never […]
The post Creating a Zip File From Multiple MemoryStreams in D365FO appeared first on Alex Meyer.
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
ievgensaxblog: D365FO. Working with Azure File storage. Blog bot DAX Blogs 0 16.07.2017 13:14
palleagermark: How to make a ZIP file from AX 2012 R2 CU7 Blog bot DAX Blogs 0 07.04.2014 11:11
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating with multiple Dynamics AX 2009 instances (AOS) and/or if currency translation and eliminations are required (Part 4 of 7) Blog bot DAX Blogs 0 07.01.2012 03:18
Часовой пояс GMT +3, время: 13:30.
