Старый 31.08.2024, 03:46   #1
25,643 / 848 (80) +++++++
How to get back Import users button in D365FO
Источник: http://alexvoy.blogspot.com/2024/08/...button-in.html
You may start experiencing the following issue with button Import users.
It happens because Microsoft changed their approach to devboxes settings:
As of November 15, 2023, certificates in your Microsoft Entra tenant are no longer installed in new one-box development environments by default.
You can find more detail on how to install a certificate in this article, but we can use a shortcut using
D365fo.tools.
Here are the steps:
1) Go to Azure portal and select app registration and create a new one (name the app to be the same as the environment name & leave settings at default)
2) The app registration needs to have the following:
a) 2 reply URLs > https:// & https:///oauth
b) add the following API permissions to the App registration:
Grant above permissions.
3) On the VM for the environment, open PowerShell
4) Run the following commands:
a) Install-Module D365fo.tools, and accept all the prompts
b) New-D365EntraIntegration -ClientId (client-id is the app registration id that was created)
5) The above command will save a certificate, which then needs to be uploaded to the app registration that was created
everythingdynamicsaxbi: How to: Successfully enable Business Events in D365FO Blog bot DAX Blogs 0 19.03.2019 23:13
NAV Team: How to get back the 'hotfix directories' from NAV 2015 Cumulative Update 1 Blog bot Dynamics CRM: Blogs 0 13.11.2014 16:25
atinkerersnotebook: Using Excel to Import Customers and Vendors in Dynamics AX 2012 Blog bot DAX Blogs 0 19.07.2013 15:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Часовой пояс GMT +3, время: 08:03.
