Старый 24.09.2024, 13:13   #1
25,643 / 848 (80) +++++++
erconsult: ZUGFeRD 2.2 import for Dynamics 365 for Finance
Источник: https://erconsult.eu/blog/zugferd-2-...5-for-finance/
ZUGFeRD (Zentraler User Guide des Forums elektronische Rechnung Deutschland) is an e-invoicing format combining a human-readable PDF/A-3 and an embedded XML file using the CII (Cross-Industry Invoice) syntax. The CII syntax may also be used in the xRechnung, which is a pure XML version of the German e-Invoice. From 2025, the ability to receive and process electronic invoices becomes mandatory for B2B transactions in Germany.
Microsoft’s current solution in Dynamics 365 for Finance provides support specifically for the UBL (Universal Business Language) format of the xRechnung: Import vendor electronic invoices – Finance | Dynamics 365 | Microsoft Learn. It enables the automatic import of vendor invoices received in this format directly into the system or placed in a SharePoint folder, mapping them as pending vendor invoices.
We are happy to announce the release of the CII (Cross-Industry Invoice) dialect of the xRechnung / ZUGFeRD electronic invoice. This solution is implemented via Electronic Reporting (ER) configurations, which means it does not require any customisations and can be easily installed across all active versions of D365. It sits on top of the standard
  • Invoice model version 280
  • Vendor Invoice Mapping to Destination version 280.46
side by side with the configuration
  • Vendor Invoice Import version 280.7.
The functionality aligns with the standard Microsoft UBL import, utilizing the key data elements for processing and ensuring PO matching:
  • Header: Invoice ID, Invoice date, Due date, Vendor ID, Currency code, and a header-level note.
  • Lines: Line number, Item ID, Quantity, Sales unit of measure, Sales price, Discount (percentage discounts are converted to absolute values as the XML schema doesn’t support percentages), Price unit, Name, Description, and Line amount (excluding VAT).
The solution supports the ZUGFeRD 2.2/Factur-X 1.0 profile EN 16931, also known as the “COMFORT” profile (being also a subset of the EXTENDED profile), which meets all tax law requirements and must be accepted by customers unless explicitly denied.
Price
The solution is offered at a fixed fee per end customer / D365 tenant:
VersionPriceDeliverablesNotesLight€890The Vendor invoice import CII Electronic Reporting configurationThis option does not require any X++ customisations or 3rd party software and can be installed and used right away.Light+€1200Same as the Light version but with 5 hours of prepaid support and installation You will soon be able to acquire the solution on the official Microsoft App Source portal.
Setup and use
  1. Follow the steps outlined in the Microsoft’s guidance Import vendor electronic invoices – Finance | Dynamics 365 | Microsoft Learn:
  2. Import the same three configurations from Microsoft (see Prerequisites).
  3. Import the configuration Vendor invoice import CII.xml provided to you.
  4. Open Accounts payable > Setup > Accounts payable parameters; on the Electronic documents tab, select the imported Vendor invoice import CII format.
  5. Prepare the master data: make sure the vendors are store with the proper VAT numbers in Dynamics 365 for Finance.
  6. Make sure that the vendor’s external item ID mapping exists. The Buyer Assigned ID (our item number) potentially sent by the vendor is neglected by the Microsoft’s mapping, and the conversion to the internal Item ID is always handled via the external item IDs. Under these conditions, the import works as expected and the PO lines may be matched.
  7. Make sure that the units of measure are properly mapped to the UNECE Recommendation No. 20 list called “Codes for Units of Measure Used in International Trade” (see https://tfig.unece.org/contents/recommendation-20.htm). E.q. the ZUGFeRD unit H87 must be mapped to either PCS or EA or STK.
  8. Perform a test upload by using the function Accounts payable > Periodic tasks > Import vendor invoices.
Useful links
E-invoice and configurable business documents blog series
Further reading:
Aktueller Stand der eRechnung in D365 for Finance (Deutschland)
Austrian Peppol-UBL e-invoice
ZUGFeRD 2.2/ Factur-X 1.0 for Dynamics 365 FO
How NOT to send an order confirmation per e-mail
Enumerate lines in Configurable Business Documents
Canvas sections in D365 Configurable Business Documents
Electronic reporting: Italian eInvoicing FatturaPA, CIG and CUP numbers, RIBA
Italian eInvoicing FatturaPA: Part 2
The post ZUGFeRD 2.2 import for Dynamics 365 for Finance appeared first on ER-Consult.
erconsult: German travel expenses in Dynamics 365 – Part 2 Blog bot DAX Blogs 0 04.01.2022 15:13
erconsult: German travel expenses in Dynamics 365 / Deutsche Reisekostenabrechnung 2022 Blog bot DAX Blogs 0 04.01.2022 15:13
survivingcrm: What’s An “App” in Dynamics 365 Anyway? Blog bot Dynamics CRM: Blogs 0 06.01.2018 22:14
Часовой пояс GMT +3, время: 11:07.
