Старый 13.02.2007, 12:30   #1
casperkamal: Using Script to create code for inserting record in a table
Источник: http://casperkamal.spaces.live.com/B...CD63!221.entry
     Few days back i came across a very interesting feature in Axapta. It is about creating code for inserting a record in a table, generally for which we take a long time looking in to the enum and etc... Believe me you can do all that in one go just try this out....
Select any form, say for ex: chart of Accounts
1.Right Click and Choose "Recordinfo" from the options,
2. a form like the one shown will appear, just click on "script" button and the code to insert a record in leder table is copied to the clipboard,
3. Finally Paste in a job or wherever you want..... Very simple
Amazing.........cute Ax
Старый 13.02.2007, 12:57   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Как раз подобную идею пишу для тройки.
Опередили.
casperkamal: Using record templates in code for Dynamics Ax 4.0. Blog bot DAX Blogs 0 10.05.2008 19:14
jerry-dynamics: How can you make sure that the end user can not delete a record in one table if there are related records in another table? Blog bot DAX Blogs 0 16.06.2007 11:20
casperkamal: A small addition to creation of Table throug x++ code in Dynamics Ax Blog bot DAX Blogs 0 03.04.2007 23:11
casperkamal: Adding a Table field through X++ code in Dynamics Ax Blog bot DAX Blogs 1 02.04.2007 17:05
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 05:10.
