#1 |
daxmy: AOT Find function
Источник: http://daxmy.blogspot.com/2007/08/ao...-function.html
============== "The Find function in the AOT will only retrieve the outer most layer objects. For example if an object has a GLS and VAR layer, Find retrieves the VAR layer. Add an option to the find to retrieve all objects in the specified layer regardless whether another layer is involved. Refer to incident 8945146 if need be." MS Community Article I do remember it was layer field in the SysAOTFind form. So I quickly run some testing on the AOT Find features, and discovered:
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
