Старый 04.11.2008, 13:05   #1
mfp: Upgrading to Microsoft Dynamics AX 2009 @ Convergence 2008
Источник: http://blogs.msdn.com/mfp/archive/20...ence-2008.aspx
Deepak Kumar and myself will be hosting two sessions on the upgrade process at Convergence in Copenhagen later this month. I hope to see you there.
Code Title Date/Time Room AX14 Upgrading to Microsoft Dynamics AX 2009 11/20/2008 10:30AM-11:30AM Hall A1 AX14R Upgrading to Microsoft Dynamics AX 2009 11/20/2008 3:30PM-4:30PM Aud 15
This session will take you through the end-to-end flow of upgrading from Microsoft Dynamics AX 3.0 or Microsoft Dynamics AX 4.0 to Microsoft Dynamics AX 2009. We'll overview the code upgrade as well as the data upgrade process, along with recommended best practices. Examples of the improved upgrade documentation, with a focus on the implementation guidelines, will be highlighted, and we'll cover tips on performing the upgrade more efficiently and effectively. You'll also learn the extra upgrade steps needed if you've extended your solution.
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
mfp: Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 14.03.2008 22:11
mfp: Upgrading to Microsoft Dynamics AX 4.0 and Microsoft Dynamics AX 2009 @ Convergence 2008 Blog bot DAX Blogs 0 22.02.2008 17:37
Часовой пояс GMT +3, время: 01:48.
