Старый 27.01.2010, 02:08   #1
crmdude: Find User with least number of Tasks due on a Date
Источник: http://crmdude.wordpress.com/2010/01...due-on-a-date/
In this scenario, we need to find a user in a team with the least number of Tasks assigned to them on a particular date so that we can assign a newly created Task record to them. This example can easily be extended to look at all activities due on a date (activitypointer record).
using System;using System.ComponentModel;using System.ComponentModel.Design;using System.Collections.Generic;using System.Workflow.ComponentModel.Compiler;using System.Workflow.ComponentModel.Serialization;using System.Workflow.ComponentModel;using System.Workflow.ComponentModel.Design;using System.Workflow.Runtime;using System.Workflow.Activities;using System.Workflow.Activities.Rules;using Microsoft.Crm.Sdk;using Microsoft.Crm.SdkTypeProxy;using Microsoft.Crm.Sdk.Query;using Microsoft.Crm.Workflow;using Microsoft.Crm.Workflow.Activities;namespace CustomWorkflow{ [CrmWorkflowActivity("Find User with least Tasks due on specified Date", "Custom")] public partial class AvailableUser: SequenceActivity { protected override ActivityExecutionStatus Execute(ActivityExecutionContext executioncontext) { # region get an instance of the Crm Web service IContextService contextservice = (IContextService)executioncontext.GetService(typeof(IContextService)); IWorkflowContext context = contextservice.Context; ICrmService crm = context.CreateCrmService(true); # endregion GetUserWhoHasLeastTasksDueOn(crm); return ActivityExecutionStatus.Closed; } private void GetUserWhoHasLeastTasksDueOn(ICrmService crm) { # region variables List users = null; int? leastcount = null; Guid leastuser = Guid.Empty; # endregion /* get a list of users in the team */ users = GetTeamMembers(crm); /* only proceed if we have found some users */ if (users != null) { foreach (Guid userid in users) { /* get a list of Task activities due on the specified date for this user */ List tasks = FindTasksDueOnDateForUser(userid, crm); /* check if this user's due Tasks are less than what we've found so far */ if (tasks != null && ( leastcount == null || leastcount > tasks.Count)) { leastcount = tasks.Count; leastuser = userid; } } } /* assign our output User variable a value */ if (!leastuser.Equals(Guid.Empty)) user = new Lookup(EntityName.systemuser.ToString(), leastuser); } private List FindTasksDueOnDateForUser(Guid userid, ICrmService crm) { List tasks = null; try { ConditionExpression owner = new ConditionExpression("ownerid", ConditionOperator.Equal, userid.ToString()); ConditionExpression duedate = new ConditionExpression("scheduledend", ConditionOperator.On, dueDate.Value); FilterExpression filter = new FilterExpression(); filter.AddCondition(owner); filter.AddCondition(duedate); filter.FilterOperator = LogicalOperator.And; ColumnSet cols = new ColumnSet(new string[] { "activityid" }); QueryExpression query = new QueryExpression(); query.ColumnSet = cols; query.Criteria = filter; query.EntityName = EntityName.task.ToString(); BusinessEntityCollection collection = crm.RetrieveMultiple(query); if (collection != null) tasks = collection.BusinessEntities; } catch { } return tasks; } private List GetTeamMembers(ICrmService crm) { List members = null; try { RetrieveMembersTeamRequest request = new RetrieveMembersTeamRequest(); request.EntityId = team.Value; request.MemberColumnSet = new ColumnSet(new string[] { "systemuserid" }); RetrieveMembersTeamResponse response = (RetrieveMembersTeamResponse)crm.Execute(request); members = new List(); if (response.BusinessEntityCollection != null) foreach (systemuser user in response.BusinessEntityCollection.BusinessEntities) members.Add(user.systemuserid.Value); } catch { } return members; } # region workflow dependencies (inputs and outputs) public static DependencyProperty dueDateProperty = DependencyProperty.Register("dueDate", typeof(CrmDateTime), typeof(AvailableUser)); public static DependencyProperty teamProperty = DependencyProperty.Register("team", typeof(Lookup), typeof(AvailableUser)); public static DependencyProperty userProperty = DependencyProperty.Register("user", typeof(Lookup), typeof(AvailableUser)); [CrmInput("The estimated close date")] public CrmDateTime dueDate { get { return (CrmDateTime)base.GetValue(dueDateProperty); } set { base.SetValue(dueDateProperty, value); } } [CrmInput("The team handling this Task")] [CrmReferenceTarget("team")] public Lookup team { get { return (Lookup)base.GetValue(teamProperty); } set { base.SetValue(teamProperty, value); } } [CrmOutput("Available User")] [CrmReferenceTarget("systemuser")] public Lookup user { get { return (Lookup)base.GetValue(userProperty); } set { base.SetValue(userProperty, value); } } # endregion }} Tagged: code, workflow
Dianne Siebold: Find User Settings in the SysLastValue Table Blog bot DAX Blogs 0 09.01.2010 12:05
daxsol: Axapta Kernel Functions Blog bot DAX Blogs 1 16.05.2009 19:22
palleagermark: Transform a date into a number of months from a specific offset date Blog bot DAX Blogs 0 27.05.2008 14:05
Часовой пояс GMT +3, время: 04:25.
