Старый 13.04.2011, 03:24   #1
East Ocean - Technical: Duplicate UUID issue with vhd images [VirtualBox]
Источник: http://eastoceantechnical.blogspot.c...hd-images.html
The latest CRM2011 required 64bits environment, with my Window 7 laptop, the alternate method is the use the Virtual Box.
Face a common issue after I tried to copy an image to from hard disk and boot with another machine. Keep on prompting me "Duplicate UUID issue with vhd images". If you guys face the same problem as me, try to look for your VBoxManage.exe file location.
then type in command prompt:
VBoxManage internalcommands sethduuid J:\VPC\yourvhdname.vhd
It will generate a new id for that vhd, thus problem solved!
East Ocean - Technical: CRM outlook client - popup blocker issue Blog bot Dynamics CRM: Blogs 0 09.02.2011 10:11
East Ocean - Technical: No organization was specified in the configuration file Blog bot Dynamics CRM: Blogs 0 18.10.2010 10:05
East Ocean - Technical: Modify the recurring system jobs' interval in CRM 4 Blog bot Dynamics CRM: Blogs 0 30.07.2010 21:05
East Ocean - Technical: SQL divide by zero "isZero" function Blog bot Dynamics CRM: Blogs 0 16.06.2010 10:05
East Ocean - Technical: CRM 4.0 Update Rollup 10 Blog bot Dynamics CRM: Blogs 0 11.04.2010 19:07
Часовой пояс GMT +3, время: 12:05.
