#1 |
palleagermark: Find you SID
Источник: http://palleagermark.blogspot.com/20...d-you-sid.html
============== If you restore the demodatabase for an AX 2012 image, you might need to know you SID in order to change your login in the AX database. This script displays your SID and copies it to your clipboard: Код: strComputer = "." Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") Set objAccount = objWMIService.Get _ ("Win32_UserAccount.Name='Administrator',Domain='corp'") Wscript.Echo objAccount.SID Set WshShell = WScript.CreateObject("WScript.Shell") WshShell.Run "cmd.exe /c echo " + objAccount.SID + " | clip", 0, TRUE Wscript.Echo "Your SID is copied to the clipboard" And this is the script you can use in the database: Код: update userinfo set networkdomain = 'YourDomain', networkalias = 'YourAlias', SID = 'YourSID' where ID = 'Admin' Источник: http://palleagermark.blogspot.com/20...d-you-sid.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 04.07.2011 в 21:20. Причина: оформление |
