		#1 |
			emeadaxsupport: Microsoft BizTalK Server 2010 passes compatibility testing with Microsoft Dynamics AX 2009 SP1
			Источник: http://blogs.msdn.com/b/emeadaxsuppo...-2009-sp1.aspx
			============== Earlier this week I was informed that Microsoft BizTalK Server 2010 has passed compatibility testing with Microsoft Dynamics AX 2009 SP1. See http://blogs.technet.com/b/dynamicsa...rver-2010.aspx for more details. I would recommend that if you are using BizTalk Server integration to at least have Microsoft Dynamics AX 2009 SP1 Hotfix Rollup 7 Kernel installed as aminimum on all your AX systems. This Kernel build contains the following AX BizTalk adapter fixes and enahnacements: 2389818: "Requested Service not found" error message when you use the BizTalk connector adapter in Microsoft Dynamics AX 2009 Service Pack 1 The BizTalk adapter cannot handle response messages from Microsoft Dynamics AX 2009 SP1 on a successful delete service action or a successful update service action and other kernel updates from previous rollups. --author: Anup Shah --editor: Anup Shah --date: 29/Sept/2011 Источник: http://blogs.msdn.com/b/emeadaxsuppo...-2009-sp1.aspx
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
