Старый 25.09.2013, 14:11   #1
kamalblogs: SSRS Tip: Prevent report execution through controller – Dynamics Ax 2012
Источник: http://kamalblogs.wordpress.com/2013...amics-ax-2012/
What a user might hate to see is a blank report. No matter where the mistake lies the earlier we react the happier the user is. Here today i’m sharing a tip on how you could stop/warn/show a info after the report execution is initiated  after the user clicks the “Ok” button in the dialog.
In the example discussed here, the idea is to check preemptively if a query will return a record or not. If no then the report aborts execution.
To implement this, open the controller of your report or create one.
On the controller class, override the method “preRunValidate”
Place the code as shown here. This method is invoked after the user clicks the “Ok” button and before the report is executed. Do not block the super call in this method as it does few other important validations. This method can return an error/warning/info. If it is a warning or error the report aborts further execution.
protected container preRunValidate(){ container validateResult = super(); Query firstQuery; int recordcount; firstQuery = this.getFirstQuery(); custStatementCount = QueryRun::getQueryRowCount(firstQuery, 6); if (custStatementCount > 5) { validateResult = [SrsReportPreRunState::Error, "No valid records found for the specified range"]; } return validateResult;}Standard recommends the method to be used for validating if the report returns a large amount of data.For reference see \Classes\CustAgingReportController\preRunValidate\
For more tips and learning about SSRS – AX 2012 order the book Dynamics AX 2012 Reporting Cookbook authored by me.
Related articles
kamalblogs: SSRS tip: Take care that VS and AX client are in the same layer for SSRS – Dynamics AX 2012 Blog bot DAX Blogs 0 09.09.2013 16:11
kamalblogs: Book review: Extending Microsoft Dynamics AX 2012 Cookbook Blog bot DAX Blogs 1 09.09.2013 16:11
dax-lessons: Get the underlying SSRS Report Query, reset query , add your own ranges and execute report [Dynamics AX 2012, X++] Blog bot DAX Blogs 0 30.04.2013 01:13
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 17:23.
