Старый 12.05.2014, 19:11   #1
goshoom: Preventing users from changing session date (AX 2012)
Источник: http://dev.goshoom.net/en/2014/05/no...-session-date/
What if you want to prevent users from going to File > Tools > Session date and time in Dynamics AX 2012 and changing the session date?
Usually, every user has access to the form, because the permission is included in System User role. If you go deeper, you’ll find SystemDate entry point in ClientEssentials privilege, which is included in SysServerAXBasicMaintain duty and this duty is assigned to System User role.
Therefore you can simply remove SystemDate entry point from ClientEssentials privilege and assign it only to the privilege/duty/role where you want it.
За это сообщение автора поблагодарили: gl00mie (2).
axaptacorner: Ax 2012 CU3 Upgrade from AX 2012 Blog bot DAX Blogs 0 18.01.2013 20:11
axaptacorner: Upgrade from Ax 2012 to AX 2012 R2 Blog bot DAX Blogs 0 18.01.2013 20:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
daxis: Dynamics Ax 4.0 Session Types Blog bot DAX Blogs 0 01.04.2009 18:05
Часовой пояс GMT +3, время: 22:32.
