Старый 12.10.2016, 19:12   #1
organicax: Route feasibility error when resource not setup correctly
Источник: https://organicax.com/2016/10/12/rou...tup-correctly/
When you are setting up a route you can assign a resource and use the route feasibility function to see if the system can actually find the resource. If you get an error then you might want to check the resource setup.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: Using a record template to setup a resource Blog bot DAX Blogs 0 12.10.2016 00:14
emeadaxsupport: When you create a route card journal the resource is not defaulting as the resource group that was listed as the resource requirement. Blog bot DAX Blogs 0 10.08.2016 02:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
DynamicsAxSCM: Using route schedules in TMS with CU10 Blog bot DAX Blogs 0 11.12.2015 17:11
Часовой пояс GMT +3, время: 05:53.
