Старый 04.02.2017, 03:29   #1
organicax: RFQ – Vendor Search
Источник: https://organicax.com/2017/02/03/rfq-vendor-search/
In an early post we have a look at the vendor auto add. If category is too narrow to search or you want a shorter list of vendors then you can use the vendor search. It works or attributes that you might flag on the vendor like minority interests etc. You can then use these to filter. Which will come up with a short list and you can remove vendors from the search list before adding to the line.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: RFQ default payment terms Blog bot DAX Blogs 0 04.02.2017 03:29
organicax: RFQ Case number vs request for quotation number Blog bot DAX Blogs 0 04.02.2017 03:29
organicax: RFQ expiration date – days offset Blog bot DAX Blogs 0 03.02.2017 21:18
organicax: cXML punchout protocol handler installation for AX2012 R3 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
Часовой пояс GMT +3, время: 15:53.
