Старый 10.08.2018, 19:11   #1
d365technext: D365FO Database Synchronization
Источник: http://d365technext.blogspot.com/201...onization.html
In Microsoft D365FO there are 3 way to synchronized the database
Full synchronization
Synchronization after build of packages
DB sync on project build
To perform a single full database synchronization Open Visual Studio and click on Dynamics 365 Menu and click on synchronized database...
Like below
Now click on synchronize
There is option available to sync database with build model feature, In this option DB with start sync after build of the model...
Navigation
Go To > Dynamics 365 > Build model
Now select model/models then click on 2nd tab and Mark checkbox of synchronized database.
The properties of a project in Solution Explorer, there is property available synchronized database of every build of project
d365technext: Batch Multi threading D365FO AX7 Blog bot DAX Blogs 0 31.07.2018 23:16
d365technext: The database principal owns a fulltext catalog in the database, and cannot be dropped. Blog bot DAX Blogs 0 31.07.2018 11:11
d365technext: Production Database backup Request Blog bot DAX Blogs 0 30.07.2018 20:13
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
Microsoft Dynamics NAV Database Archive for all Country Versions Blog bot Dynamics CRM: Blogs 0 11.03.2011 18:43
Часовой пояс GMT +3, время: 18:45.
